troymail
Silent Key
Anne Arundel Engine 27 (Maryland City) was just active on TG 1133 (Ch 1 / 8A1) -- Pro96Com is now showing 1133 on as FDMA
Can the PSR-800 and PRO96COM work together? If so, how?
All zones in the FD system are up and running. As far as what talkgroups are active see post #1. It does not matter if a new radio is on the talkgroup or not, all the present channels are tied into the new system per post #1 and will remain that way until the changeover is completed.
I also had PRO96 running for a couple of hours last night. The only consistent FD TG's coming up were A1 (1133) and the PD TG's. I was also monitoring Channel 2, 3,4 and 7. No TG hits were showing for the channel 2 and 7 activity on PRO96.
I am confused as well.
Is there a place to list wildcard hits in PG county, I don't want to add them to the database until they are confirmed.
The reason I ask is tonight at the drive at 5, I got 8 wildcard hits, I am going to turn on the audio recording to try to figure out who they belong to.
Thanks,
Steve
Or as I have mentioned on many occasions <sigh>, you can use the wiki to track unknown talkgroups - there's a section reserved for them in this article;
Prince George's County Project 25
I would encourage posting all that info in one place - that way when everything is settled down and mapped, it can be submitted to the DBA en masse, instead of piecemeal.
It's not hard to learn how to edit in Mediawiki - really! All you need do in it's simplest form is to precede each talkgroup with an asterisk in the leftmost column - no need for hard coded breaks or any other messy HTML code. It's done like this;
* tg1133 - multiple fire channels patched here
* tgxxxx - put your description here...
Anyone can edit most any of the pages in the wiki - if you have trouble signing on please send Lindsay an email - the admins do not have access to the password/user id servers
best regards..Mike
Tell me this troy, you saved 25, could you donate 12 1/2 bucks for my test?![]()
I'm wiki-challenged.... so if someone can add these please. I have verified them.
211- Greenbelt City
205- Hyattsville City
199- Laurel City
223- Mt. Ranier
