Dewey
- Joined
- Dec 19, 2002
- Messages
- 1,025
Drove around the Bowie area trying to listen to the apparently few fire talkgroups that are "Active" (Ch 1/TG 1133, Ch 2/TG 1135, etc.).... On the drive TG 1135 (8A2) stopped again - like someone either pulled the plug or the activity went away from some other reason.
Driving northeast a bit from Bowie into Crofton, the system nearly fades away again...
I sure hope they boost the power on this system...
Due to some of the discussions going on in the post PSR-800 thread over on the GRE forum, would it be a problem if you put your PSR-800 into search mode (?OPEN?) the next time you drive near the PG area? Since PGPD is full time TDMA, you may be the first who can answer if the PSR-800 is already capable of following TDMA.
Dewey
