So, are the NMO antenna mounts the type you drill holes in your vehicle to mount?
I googled it, and it seems to show only mounts permanently drilled into the vehicle.
Like I say, I can't drill any holes in this vehicle, at least not yet.
The NMO mount was originally designed for mounting through the roof of a vehicle, however it'll mount in a 3/4" or 3/8" hole, depending on the model you purchase. Any bracket that you can make a suitable sized hole in will work, HOWEVER, you do need to pay attention to the underside:
The standard NMO mount was designed to mount through the roof of a vehicle. The outside part is waterproof. The underside of the mount is designed to be inside the vehicle. Installing an NMO mount on one of these brackets exposes the unprotected underside to rain, snow, road salts, oil, etc. Water will quickly get into the coax and underside of the mount and cause issues. You'll need to take some precautions to make sure it's all properly sealed on the underside.
Here's some generic fender mounts with NMO's:
http://www.theantennafarm.com/catal...ounts-296/nmo-bracket-mounts-with-pl-259-500/
How about this:
Oh hell no. So many things wrong with that on so many levels. Occasionally when I go to the local ham radio swap meets, you'll see a guy or two with a car like that. Never understood the mindset.
Just imagine what the fuel economy and wind noise must be like.
Back in the day we would have referred to that as a "birth control vehicle". No way you'd ever get a girl in a car like that.
