I have a friend with the JPS NIR-10 audio DSP filter with the latest software ROMs (Amateur version) with NAR: 250Hz, MED: 600 Hz, WIDE:1800Hz filters.
JPS also sold the NIR-10 as a Shortwave version and the only difference I can see is wider filters (SWL) NAR:1800Hz, MED:2400Hz, WIDE: 3000Hz.
It looks like the exact same unit with only a minor change for filter size (ROM Programming/Jumpers/Diode/etc).
Does anyone know the exact change and can the Amateur version be converted/changed to the Shortwave version?
BTW, How do you tell the SWL Version from the Amateur Version by looking at it. I know the Amateur version don't have Amateur on the label but is the SWL version clearly marked somewhere?
If it can't be converted, what's the best mode to listen to noisy Commercial Shortwave Broadcast Stations (Bandpass mode/Wide Filter 1800hz or Bypass peak mode)?
