Progress and interop.. and a lil ole 'cane named Katrina... convinced MS to upgrade thier ancient VHF systems to a state of the art fully digital 700 MHz statewide Motorola ASTRO-25 trunked radio system. There are still several areas that will be hearable without digital ability on a scanner... In the Jackson Metro- Hinds County EOC/VFD's on the CMSRTRS, Rankin County is still on an analog Motorola TRS, Copiah County is all analog VHF Hi conventional, Simpson and Yazoo if you have an LTR capable scanner... The Railroads, both CN/IC and KCS... Jackson/Evers International Airport.. still analog EDACS TRS.... As well as the Aircraft. Oh and Jackson DPW... Analog on the old EDACS TRS.. And MS DOC's EDACS system which is still analog with a little AEGIS Encryption. The following are currently digital... JPD, JFD, HCSO, MCSO, RPD, RFD, CPD, TPD, MPD, UMCPD, MSSCP, Holmes CC PD, MFD, AMR on the TRS, though AMR still uses the VHF Hi analog too, and they are also on the Rankin County TRS, Vicksburg/Warren County also digital on the SAME type of Motorola TRS as Hinds, and Madison Counties, and may be joining that net.... Agencies that will be going to MWIN- MHP, MBN, MF&A, MDWF&P, MDOT, MEMA as well as both MEMA and MDWF&P having satellite radio systems currently... MDOC will also join on the MWIN, but will phase out thier statewide EDACS TRS. MSU, UM, and USM will at the very least have TG's on the MWIN. JSU PD uses both the old Jackson EDACS, and the CMSRTRS. On the EDACS they are analog, digital on the Motorola.
