When programming a gmrs vx3200 mobile radio with gmrs ch.
gm991
boston
When programming a gmrs Vertex vx3200 mobile radio with gmrs channels
How do you deal with the 38 privacy codes my bubble pack midlands have.
Do you have to program in all the codes?
How does it work?
Will I be able to talk between the two on all gmrs ch.?
gm991
boston
what ever code your "bubblepack" radio is set on per channel, is what you have to have per channel in your vertex.
So if I wanted every ch option like on the bubble pack radio on my vertex I would need to program the ch freq. plus all the 38 codes, so one gmrs freq. channel would have 38 different memory slots for that one freq. channel?
If that's the case maybe it would make sense to just program all the gmrs ch with no codes and just set up the bubble pack radio on the channel with no codes??
WA0CBW
Shawnee Kansas (Kansas City)
Unfortunately most commercial type radios only allow one PL code per channel. So to change the PL code the radio must be reprogrammed with a new code. Unlike the blister pak radios that allow you to manually select any of the PL codes available.
BB
gm991
boston
BB
Ok
Now I understand.
Sorry for the silly question...:)
