Where can I get pre-loaded 996 files?
wm8s
Houston, TX
They came with my version of the UASD programming software. Or you could reset your scanner with ROM reload, and then read them out and save them.
DaveIN
Founders Curmudgen
West Michigan
They also come with the Butel 996 Clone program. Just in case you wipe everything out.
RISC777
Or/And if you reset the scanner (press and hold 2, 9, and Hold while powering it on), actually called "initializing the scanner's memory." You will be prompted if you want the factory's pre-programmed systems loaded.
But, all programming will be erased / lost.
