Where is MOTOTRBO CPS in MOL?
MFG_rrt
In MOL this is all I see. It doesn't look like an installation file for the MOTOTRBO CPS. What am I missing? I just ordered MOTOTRBO RADIO MGMT LIC, do I just need to wait until that processes until it shows up?
82582
N1GTL
CT
It's not listed there. Call MOL. Probably a permissions issue if you paid for the subscription.
MFG_rrt
Ok I think that's the confusion then. I don't think I paid for a subscription. I purchased (for free) a License. So I'll have to go take another look.
Thanks.
MFG_rrt
that may explain it. CPS is a subscription product, so they'll probably sell you a sub and once paid, they'll add it to your account and then you can download it.
That's how I remember it when I bought the APX CPS, but I guess I assumed the item I had in my cart was the actual subscription.
Thanks everyone.
MFG_rrt
I can't edit my original post anymore, but I finally got access to my downloads (MOL changed since my last purchase).
What's the difference in:
MOTOTRBO CPS 16.0 Build 828 (Standalone)
and
MOTOTRBO CPS 2.0 2.21.61.0
K2NEC
5F6
CPS 16 is the older CPS (the better CPS)
CPS2.0 is Motorola's new version of the TRBO CPS, and if you have done any searching at all you will find that 99% of people dislike CPS2.0 very much.
If you can, absolutely avoid CPS2.0 until Motorola can fix it or completely dump it(Yea I know i'm completely dreaming here).
cmpsa
I have a quick question RE "MOTOTRBO CPS 16.0 Build 828 (Standalone)". I have it installed in 2 computers (Windows 7). I just downloaded the firmware update files (under "Conventional - Firmware) menu item. Once you download the firmware file, you have to extract it and it installs the firmware file "package" on your hard drive/computer. Then when you are in the CPS software and you read a radio, you can select to "upgrade" the firmware. Both of my computers are doing the same error. The "packages" are installed & show in the "programs" list, but the CPS software doesn't detect/or find the recently installed "packages". I have rebooted the computers over & over and it still won't detect them?
Has anyone ever encountered this problem before? Both computers share the same CPS software & same firmware files, both are having identical issue.?. Thank you!
MFG_rrt
I'm having different issues. My radio is on version CPS 12.00.16, when I installed CPS 16.0 and try to read the radio it gives an error saying unable to detect an applicable device. How do I resolve?
n3obl
ØAES-1056
PA
Try uninstall and reinstall also try cleaning contacts on your radio.
K2NEC
5F6
Have you tried turning it off and on again?
No seriously, connect the programming cable and power off and on the radio. Your computer should then recognize it and it should work. I had that problem once and I couldn't figure it out even though radio recognized the cable.
n3obl
ØAES-1056
PA
Also sometimes the computer needs rebooted.
MFG_rrt
So I think it's a driver issue but I don't know how to resolve.
Firmware is: R02.08.01.0000
I downloaded CPS 16.0 build 828
My PC (Win10) is recognizing it as a COM port. I don't know how to get the right drivers.
MFG_rrt
Nevermind. I just went into MOL and downloaded the driver. DUH
