@rdubs8080, here is the Repeater Book listing URL for the Phoenix, Arizona Amateur Radio (ham) repeaters:
Your HT is capable of the frequencies in the 14x.xxx MHz and 44x.xxx MHz ranges and where the mode is FM.
There is a better way to list the repeaters in your area but we would need your zip code. Then we could search using a radius of "TBD" miles from the geographic center of your zip code. The radius is determined by whether you will be using your HT with the stock antenna inside your house (0.5 to 2 miles), outside your house using your HT with the stock antenna (2 to 5 miles) or you want a wide area around your zip code (up to 25 miles). Of course, at some point there may be more frequencies than you have memory locations for. The TIDRADIO TD-F9GP HT can hold 128 frequencies that can be either simplex or repeaters.
As for Public Safety, your area is found on this listing:
Scanner Frequencies and Radio Frequency Reference for Maricopa County, Arizona (AZ)
www.radioreference.com
Phoenix Fire does have some FM narrowband listings in the 15x.xxx MHz range however, they are also on the area's trunked radio system. What that might mean is that these frequencies could have been abandoned. To find out more information on that, you may want to press the "
Report" hypertext in the lower-left of this post and ask that this thread be moved to the Arizona state forums where you will get folks local to the area that are hopefully more knowledgeable than I on what frequencies Public Safety can be found on.
Phoenix Police and Phoenix Fire appear to be Project 25 Phase II on the Regional Wireless Cooperative (RWC) system which your radio cannot receive. There is also a fair amount of full-time encryption going on with the talkgroups that no scanner can receive. The RWC system is found at the following link and any talkgroup with a capital "E" is full-time encrypted.
Regional Wireless Cooperative (RWC) Trunking System Profile
Anyway, I hope that all of this is not too confusing and helps you to get started on your journey.
73, Dave K4EET
