where to buy an antenna
kaitlin4599
tucson,az
hello i have a uniden SC150B police scanner with a standard rubber ducky antenna and i want to buy a better anteena first off what kind of conector does my antenna have and second are there any reputable sites on the net where i can buy an antenna for my scanner
russellmaher
Enfield, CT
The SC150 uses a BNC connector and that's what you'll need to make the hookup to the scanner.
Next thing to know is do you want the antenna for outside the house or to mount on your vehicle?
Give up some more info on the local agencies you want to listen to will be helpful.
There are lots of reputable dealers on the net that sell antennas and suggested sites will be furnished when you reply to the questions.
Russell
NWI_Scanner_Guy
Hammond, IN
ebay has a slew of antennas.
He said reputable. LOL :D
Just kidding. I've gotten quite a few good antennas thru eBay. A nice 2 meter J-pole, a couple of dual band mag mounts for my Ham HT's and a couple more mag mounts for my scanners.
As was already said, figure out what you need and/or where you want/need to mount it (them) and that will go a long way to helping you figure out what you need.
W8RMH
Feed Provider Since 2012
Since the OP mentioned the SC150B and replacing it's rubber duckie I will recommend better handheld antennas.
Here are a couple sites with a nice selection:
Scannermaster - Portable Antennas for Police Scanner Radios
Universal Radio - Scanner Antennas
Personally I prefer amateur or commercial antennas. My favorite handheld antenna is the Comet CH-32. At 1.75 inches it is easy to carry and works great for local handheld scanner coverage, unless you are hampered by mountains or trying to receive something far away.
n5ims
One key piece of information you failed to supply is what frequency/frequencies or band/bands to you monitor (note I'm not asking what your radio covers, that's not important unless you actually listen to the full range, most folks don't). This is important since an antenna is frequency dependent. A great antenna for the 800 MHz band (think 850 - 900 MHz here) will work quite poorly on the VHF-Low band (think 30 - 60 MHz here) and vice-versa.
Be aware that most of the antenna specs you see are written by two totally different types of folks, the engineers (where does the antenna actually work well) and the marketing folks (just how many bands can we say it works on without outright lying, misleading is just fine). The engineer may design an antenna to work on the VHF-Hi (think 140 - 160 MHz here) and UHF (think 430 - 500 MHz here). This is where the antenna will actually work well. They pass it on to the marketing folks that say it will work from 50 - 950 MHz so it will look like it matches pretty well with the range most scanners, their target audience, work. That antenna will work well on the VHF-Hi and UHF bands as designed and yes, it will work on the other frequencies as advertised. You may need to be standing right under the station's tower to hear it, but it will work there. The key may be where the antenna will transmit on (not that you plan to transmit, but that's where the antenna is designed to work well) since those numbers are much harder to fudge.
Don't get confused by someone saying that their antenna is designed to work with the "new digital systems". OK, while that may be true, the antenna doesn't actually know if the signal is analog, digital, TV, morse code, or a signal used to trigger an automatic door opener at a grocery store. If the signal is on 156.7890 MHz and the antenna is designed to work on 156.7890 MHz it's a good match! If that same signal is on 156.7890 MHz and the antenna is designed to work only on 789.1234 MHz it's not a good match.
