Where to get a coax crimper
ASAD
Hi all. I'm trying to buy a crimper for RG-58, LMR-240 and LMR-400 cables. When I google this I see crimping tools mostly for TV cables. Could someone tell me where to get such thing as one-fits-all? I'm not a pro, so it doesn't have to be that expensive.
Since I'm posting this, I'd like some insight on N connectors types; solder, compression and crimp as to which one is stronger.
jeatock
090-45-50 W, 39-43-22 N
You get what you pay for. If you don't do more than a couple dozen a year it's a balance between function and budget.
I use these Greenlee CrimpALL Crimper Frame Only, Series PA8000 - - Amazon.com (or the Paladin equivalent) with replaceable / interchangeable dies. The dies are pretty standard and should work between crimpers from different manufacturers. I have two handles in my coax box so i don't have to change dies often, but then again I buy connectors by the gross. When you aren't crimping coax use the wire crimper dies for ring terminals and splices- they are head and shoulders above the wire crimpers you buy at Lowe's. You can get combo dies in just about any set of diameters. Be forewarned that each connector type and manufacture may have a different spec.
Stay away from single size coax crimpers with fixed dies unless it fits the budget and you don't use them a lot. Once over-tightened and sprung they're worthless. The high-end frames have adjustable stops- one of mine is over 20 years old.
Putting a connector on coax is really two separate functions: Mechanically keeping the coax attached, and minimizing RF loss. Doing both requires dollars, and there are often cheaper ways of doing it. I would put my emphasis on the RF side if you have to make a choice.
For flexible coax the attachment to the connector isn't going to survive much tension pull any way you do it. You need to secure the coax before the connector to keep it in place. If a sharp angle at the back of the radio is an issue buy a 90 degree adapter or put a 2" rubber boot on the coax and slide it up to the connector when it's installed.
For transmitting UHF and 800 I prefer solder, but haven't been able to prove that it is much better. VHF doesn't really care (at least 50 watts and less). 2.4G is a definite solder for smaller diameters, but there are many styles of non-solder connectors that seem to work just fine with LMR400 in all bands. Adhesive-lined heat shrink is your friend.
The N-family (N, BNC, TNC, etc) has less impedance miss-match than UHF-style because the diameter ratio remains constant. That said, Mother puts mini-UHF connectors on everything mobile. Kenwood puts N's on their 800 models.
You are, for the most part, dealing in the final 2% of signal improvement. You need to ask yourself if improving 98% efficiency is worth spending a few hundred more dollars.
rwwheat
Waldheim, LA USA (St. Tammany Parish, Louisiana US
Coax Crimping Tools, Dies and Connectors
I bought my crimper and additional dies from RF Parts Company. There are many other sources for these tools such as DX Engineering, Quicksilver Radio, The Antenna Farm, etc. You can purchase a kit with multiple dies or just the tool with a single die, then add additional dies as needed.
The RFA-4005 series from RF Parts is the version I have. Similar, if not eh same tool can be purchased at other vendors.
Hamfests are a great place to find these tools both new and ued.
RF Parts, Quicksilver Radio and DX Engineering are reputable companies and I have purchased from all three..
When I purchased my original tool in 2008 I chose RF Parts because theyn had an extensive collection of connectors both name brand and imported.
