BC125AT: Where to start Was:Help
Unionguy876
I just bought a Uniden BC 125AT compact scanner so my wife and I could listen to local police and fire, how do I start scanning? Can someone help me with getting going or give me direction to get started, thank you.
engine183
Mount Orab, Ohio
The best way to provide you help is for you to be more specific with your location and what PD and or FD you are hoping to receive. The BC125 is somewhat limited. It will not work if the agency is transmitting digitally.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Welcome to the RR forums, Unionguy876. Please reply back with agency specifics so we can have a look at the database to see if your scanner is the right tool for the job. The BC125AT is an analog-only scanner with coverage only up to 512mhz so I'm hoping for your sake your local emergency services are analog with no encryption. Otherwise I hear it makes a superb aviation band receiver.
Unionguy876
I live in Livonia MI (Wayne County) so at least my city, what would be a good scanner to get?
wtp
Port Charlotte FL
the 125 will not work.
in fact for your city nothing will work all PD is encrypted.
they are on
Michigan's Public Safety Communications System (MPSCS)
Project 25 Phase II
APCO-25 Common Air Interface Exclusive
Wayne County (82) Livonia Public Safety​
70351b7bDE538P911Police Dispatch
the DE mean P-25 phase 1 full time encryption.
Whiskey3JMC
Philly burbs 🇺🇸
Well I wouldn't say "nothing" will work. Fire appears to be "in the clear"
2914b62D82F911County FireFire Dispatch
1274731cbD82LFD1Base 7 Fire DispatchFire Dispatch
223455749D82LFD ERBase 7 Fire EnrouteFire Dispatch
1274831ccD82LFD2Base 7 Fireground 1Fire-Tac
But for that the OP will need a P25 Phase-I capable receiver to bring them in:
Ronaldski
MI DB Admin
Bay City MI
125AT is not digital, cant get the 800 MHz frequencies and not a trunktracker IV or V scanner. Hopefully you just got it and able to return it.
Ive had a couple people here get these for Christmas and asked me about them and mentioned to return them as well.
Uniden model’s that are digital, prices lowest to highest:
996P2, 325P2, 436HP, Home Patrol2, 536HP, SDS 100, SDS 200.
The SDS models are expensive, but work flawlessly in counties as Wayne with multiple towers, called simulcast which can be an issue for reception on the non SDS' scanners depending on your location. Hopefully if your closer to one of the towers will be better.
Locations - Click the three FCC license links next to "FCC Licenses" Michigan's Public Safety Communications System (MPSCS) Site: Wayne County Simulcast
Current ones that won’t work, since they are not digital or a trunktracker-
365CRS, 355-all 355 model types, 125AT, BCT15X, BC75XLT, WS1010 and WS1025, All Baofeng’s
Go here https://www.radioreference.com/db/sid/100 then in your browser on computer, do a Find with CTRL-F and type in Livonia or go about 90% of the way down for Livonia listing. Wayne county starts ~80% of the way down.
Under MODE if it’s D or T it’s in the clear, De or Te sometimes clear, sometimes encrypted, DE or TE is always encrypted.
  • Like
Reactions: wtp
