Wheres the preloaded data?
Nordland
Great lakes state of MI.
I just bought a RS PRO-2096 and and do not know how to program it so I was going to us the preloaded freqs for Michigan #8 in the manual....but when I tried to load it it just said "blank"?
Theres no Michigan Preloaded freqs??
Should I take it back....and ask for another scanner?
Nordland
DaveIN said:
Chances are none of the new ones have the preloaded data, but did you check any of the other V-Folders? PGM-Func-PGM, 2-LOAD, number key 8?
You can download the "old" files and install them with Win96 if you have a programming cable:
http://starrsoft.com/software/win96/default.asp
http://starrsoft.com/software/win96/default.asp#v-scanner
Yeah....all the other preloaded state freqs are there...I loaded Ohio...because I figgered it was close..so mebbe they use the same freqs?
All the #s had there preloaded data except MI.?
No it did not come with a puter cable.
This is to complex for my feeble old brain:D Im used to my old 2030 that all you have to do is punch in the freq and hit enter! :D
Heck I can practically throw a rock and hit the darn tower from my home.:)
DaveIN
Founders Curmudgen
West Michigan
Looks like Calhoun County. Here's what you do:
Turn on the PRO-2096.
Press Man, PGM, 000, PGM.
Type in 868.925, press "E" to enter, now press MODE until it says +MO in the upper left of the display.
Press PGM again.
Enter 868.425, "E" to enter, now press MODE again until +MO is displayed.
Press PGM again.
Enter 867.925, "E" to enter, press MODE until +MO is dispayed.
Now press MAN. Press FUNC, Press TRUNK, press MODE until you see "Bank 0-0 ON ID No. 00 Motorola" on the display.
Now press SCAN.
You should start hearing and seeing talkgroups when the system is active.
Here are all the tower frequencies:
114 Albion* 866.27500 866.92500 867.42500 867.92500* 868.42500* 868.77500 868.92500*
Here are some of the talkgroups you will hear:
Calhoun County (13) Talkgroups
DEC Display Description
3077 13DRUG Countywide Narcotics Enforcement Common
3235 13P911 9-1-1 Central Police Dispatch (Patched with 155.535)
3248 Battle Creek - Police - S.I.U.
3287 Battle Creek - EMD
3872 13PD??? Albion Police - Dispatch
3876 13PD??? Marshall Police - Dispatch
You will also hear other talkgroups from other counties or state agencies:
http://radioreference.com/modules.php?name=RR&sid=100
Nordland
Hey Dave....I did like you said...but all Ive heard so far is the preloaded channels I loaded from Ohio.....is there anyway to delete all channels and start over with my local Albion channels?
DaveIN
Founders Curmudgen
West Michigan
Load the V-Folder "scratch pad". PGM-FUNC-PGM, 2-LOAD, press "."<--The decimal, "E" to enter, follow the prompts.
Then do your programming.
Nordland
Now thats more like it....its working great thanks my brother:)
I appreciate you taking the time to help me out...they should have had you write the manual! :)
Oh yeah.....I deleted everything...then the scanner rebooted...and I started from a clean slate....programed in all my freqs......these digital scanners are the cats pajamas!:D
