Which battery is better..
ff_emt121
Which is a better battery, a 7.2 Nickel metal hydride battery or 7.5 Nickel metal hydride battery?
For a motorola ht1250
conve36
Menifee/Lake Elsinore, Ca
I am pretty sure that radio takes a 7.2v battery. And the voltage doesnt make a battery better than another battery, a device technically only uses a certain voltage battery. Now "mah" or "mili-amp hours" is what you want to look for. A 7.2v 1400mah battery will not last as long on a single charge as a 7.2v 2000mah battery.
N1BHH
Jackson Square, East Weymouth, MA.
There is no real difference when it comes to voltage. Going from 7.2 to 7.5 means nothing. What you are looking for in a longer battery life is the current rating. If a standard OEM battery for a given radio is 1500 milliampere/Hour and there are batteries available (all over the web) then go with one which is of higher current rating.
N
N_Jay
Guest
NiMH batteries have a nominal cell voltage of 1.2v.
So the batteries are 7.2v
The one labeled 7.5 is nothing more than a marketing trick.
mrweather
Then I guess Motorola has been engaged in marketing trickery because all the handheld batteries I've had were labeled "7.5V" both NiCd and NiMH.
