I know that when i listen to WX channel 6 has more static on the 536 and sounds better on the 996, would that indicate which one is stronger
It would indicate that one is doing a better job pulling the signal out of the noise than the other. That could be that the 996 is more sensitive, or it's just doing a better job dealing with other strong nearby signals.
There can be a lot of variables in the radios. Even identical radios will have different performance. Component tolerances are a thing, and that varies from radio to radio and will make each one act differently. Best you can do is test each radio with the same antenna and see which one works better in each situation.
