That's one of the major bugs in SDS scanners that Uniden needs to fix. For no apparent reason they slowed down scan rate to half in one firmware version and all that followed. Search speed are still the quick one so there's no hardware or logical reason to reduce scan speed. It's been like that for 2-3 years without Uniden doing anything about it, or releasing any type of firmware update, besides the ones to handle new hardware components to replace obsolete ones to be able to sell scanners.Can the 536 scan faster I have delay receiving
Would taking off pl tones are adding priority channels are removing channels with the same frequenciesThat's one of the major bugs in SDS scanners that Uniden needs to fix. For no apparent reason they slowed down scan rate to half in one firmware version and all that followed. Search speed are still the quick one so there's no hardware or logical reason to reduce scan speed. It's been like that for 2-3 years without Uniden doing anything about it, or releasing any type of firmware update, besides the ones to handle new hardware components to replace obsolete ones to be able to sell scanners.
/Ubbe
Is the 996P2 scan rate slowUniden only checks for carrier when it scans, so squelch level are important. If it detects a carrier it then tries to do what the channel are programmed to do in the scanner, detect subtone or a digital signals color code or other parameters and when its done doing that and didn't find a match it will continue to scan. So any carrier or interference will slow down scan rate. If you set the squelch to zero it will try and decode whatever is in the noise and scan rate are then down to 4ch/s.
/Ubbe
It's only the SDS100, and probably also SDS200, that are running at half speed. Most other Uniden scanners run at 80-90ch/sIs the 996P2 scan rate slow
The 536 and 996 seems slow to me compared to Pro-197It's only the SDS100, and probably also SDS200, that are running at half speed. Most other Uniden scanners run at 80-90ch/s
This half speed happened when the sample rate for the debug log was reduced to half, some sort of firmware coding mistake where done. Debug log doesn't exist in other scanners.
/Ubbe
You can easily test by creating a conventional analog department and create a search range using Proscan or ARC, both have demo mode that allows you to do that but ARC needs the resulting channels to be copied and pasted into Sentinel. Use something like 500 channels and take time how long it takes to do one scan cycle and divide 500 by the time in seconds. Remove antenna to not receive any signal that will interrupt the scan. Then use a suitable program to do the same to your Pro-197.The 536 and 996 seems slow to me compared to Pro-197
With the Pro-197 I have some without pl tones didn't know if the 996 could be programed like thatYou can easily test by creating a conventional analog department and create a search range using Proscan or ARC, both have demo mode that allows you to do that but ARC needs the resulting channels to be copied and pasted into Sentinel. Use something like 500 channels and take time how long it takes to do one scan cycle and divide 500 by the time in seconds. Remove antenna to not receive any signal that will interrupt the scan. Then use a suitable program to do the same to your Pro-197.
/Ubbe
Can it be done with softwareyes, the 996 can be programmed without PL tones.
Yes, When entering in a conventional frequency, keep the Audio Type set to All. which is the default. Same as entering in using the scanner.Can it be done with software
I have 4 channels that uses the same frequencies would that speed up the scan rateit is a setting that you don't have to set...unless you want or need to.
Would taking out duplicate frequencies help scan fastercould you be a bit more specific ?
