Which is the better scanner
Bonkk083
Union, SC
I have a BCD536HP and BCD996P2 the 996 is 20 better on the RSSI than the 536 and I read an article saying that less RSSI is the more sensitive scanner, I like both scanners I'm using one mostly for VHF, which one would be more sensitive for VHF?
KevinC
Other
Super Moderator
Home
Which article did you read?
Bonkk083
Union, SC
The Sensitivity in a Radio Scanner is designed to measure the signal strength of a radio station. It is measured in microvolts (uV). A smaller number indicates a more sensitive receiver since less signal strength is needed to hear the station. Sensitivity is primarily of importance in rural areas or when listening to weather forecasts on the radio.
KevinC
Other
Super Moderator
Home
Ok. RSSI and sensitivity aren’t the same thing so you know.
KevinC
Other
Super Moderator
Home
Just noticed you said a difference of 20. That would be in the tenths of a dB range, way below what you can hear. Parts tolerances could easily account for that. I’d move on and not focus on such a minuscule difference.
Bonkk083
Union, SC
