Which mobile antenna?
N1GTL
CT
I am trying to decide what to do between the following antennas:
http://revanchellc.com/cgi-bin/miva...uct_Code=NMO150-450-800&Category_Code=AMMULTI
OR
http://www.scannermaster.com/Austin_Spectra_Mobile_Antenna_p/04-540720.htm
If I buy the Larsen, it is about 16" and I can mount it on the ROOF of my Explorer. If I buy the Austin, I will mount it on a 90 degree bracket attached to the front left fender coming out the crack between the hood.
With the Larsen on the roof I will have a nice big ground plane (the whole roof) versus having a bigger antenna but no real ground plane. 90% of what I listen to is above 400 MHz so I am leaning toward the Larsen. Am I missing any considerations?
northzone
Northern California
I have both of those antennas and have tried dozens more over the years. From what I have found, a 1/4 vhf whip (a simple rod cut to about 18 inches and $6 from larsen w/o mount) works as good as anything I have used on vhf and above. Of course of you need lowband lenght is important, but the vhf whip works ok even on lowband.
prcguy
I have several of the Larsen tri-banders and a few Maxrad BMAXSCAN1000s. They are very similar but my perception is the Maxrad works better on VHF hi and VHF/UHF aircraft, which neither antenna is actually tuned for. The Maxrad is also NMO.
prcguy
trooperdude
SFO Bay Area and Las Vegas NV
I would have to agree. I run a Sti-Co whip cut to 18inches with an NMO mount and
it performs well on vhf/uhf/800 and even on 42mhz for CHP.
I tossed my larsen tri-bander a few years ago, and went with the 1/4 wave VHF whip.
Kwstalk
kwstalk
I drive a big rig and would like to put a scanner in my truck. The 1/4 wavw VHF whip sounds like something that would work for me. My question is where is the best plave to get one?
trooperdude
