Which Programmer or RPM version do I need?
RK3AAG
Russia
Hi all!
Come across with P7170 aka System one. Here is RadioMaint data (attached).
Tried ProGrammer 8, ProGrammer 18, RPM 4 and PRM 10. But none of them is working :mad:
PG 18 says that radio was programmed with later SW version. But RPM 4, that radio or Flash/DPS code is not compatible with this software.
Which ProGrammer or RPM version do I need? I want to read it before change something. Don't want to write my created from scratch set.
Thanks!
mm
oregon
It's right there in the screen you provided.
RPM Version# in Hexidecimal 0x14, so none of your versions of RPM are close.
mm
oregon
Huh
No, you need RPM version 20 or later, I don't know what version RPM is at now.
Forts
Ontario, Canada
This used to be the rule of thumb that I went by:
Personality revision 31 indicates the radio was last programmed with version 17. (Revision minus 14 equals Programmer version). For RPM-programmed radios, 50 means RPM v. 1, 51 means RPM v. 2, 52 means RPM v. 3, etc.).
Now, that being said... I have an XG-75 beside me that was programmed with RPM14 and the personality version is 90.
