which radio scanner would be best for me?
photopro
Wadsworth OH
I'm using an OLD Radio Shack Pro-94 and want to upgrade to a good trunking scanner that has a computer interface.I moniter Ashland,Ashtabula,Carroll,Columbiana,Cuyahoga,Erie,Geauga,Lake,Lorain,Mahoning,Medina,Portage,Richland,Stark,Summit,Trumbull,Tuscarawas,and Wayne counties in Ohio.
eriepascannist
Chautauqua county, NY
Sorry I can't be of more help, but Uniden has a long line of fantastic trunking scanners on the market. I have a BCT15X, and it is a good radio, be it confusing to set up at first (for me, anyway.) I would check out the Uniden section on Scanner Master - Police Scanners by Uniden Bearcat, AOR and Radio Shack. and see which radio looks good for you, along with advice from others. Definitely go Uniden, though.
N8IAA
Fortunately, GA
Since you have a handheld, I presume that you are looking for the same type of scanner. For most all of OH, you'll need a digital scanner that handles P-25 and 700MHz for the new towers on the Ohio MARCS system. I suggest either the RS Pro-106, GRE PSR-500, or the GRE-PSR-800. The first two can be programmed via Win500 software that can be downloaded at www.starrsoft.com . It has a free thirty day trial. The PSR-800 comes with its own software, and has the entire Radio Reference database on a micro SD card. All have the capability to be programmed by a PC. I'm going to suggest that you go to the Ohio state forum to get more informed answers:)
HTH,
Larry
