niceguy71
I was wondering if someone ever put a large sheet, of sheet metal on the rooftop of an RV.... something like two 4X8 sheets over lapping so they touch..... maybe painted it and then pop riveted it to the top of the RV and sealed all the edges... then a mag mount would work... but a great working mag mount CB antenna like the Stryker SR-A10 MM is 66 inches tall and if the RV is 12 feet tall.... YIKES... most bridges are around 14' 6" so that would never work
but it was a nice thought.
a quarter wave CB antenna is about 9 feet tall... you may have a coil in the middle so it's shorter but the working antenna is really about 9 feet tall..... that is one side of the antenna.... the opposite side of the antenna called the counter pose also has to be 9 feet of flat metal under the antenna ... so you really need 9 feet of metal on the top of the RV.... it would be awesome if the RV was aluminum as aluminum works as good as steel... then you could just put a small metal plate on top of the aluminum to attach the antenna..... but I never really thought about how tall RV's are.
I was looking to see if anyone did it and how it was working.... I found this video IT"S NOT A CB ANTENNA but I still thought it was interesting... the guy has a lot wrong... the size of the metal ... he then says he put a very light coat of paint on it so it would still get a ground plane ( a mag mount works through capacitive coupling so the paint thickness doesn't matter) ... he had a few other things wrong too.
at the end I was hoping he would show himself talking to people... but he didn't..... and that generally tells me it didn't work.
I like to have a really good working CB in my vehicles... so if it were me and if the RV wasn't so darn tall, I'd be putting up 4 X 8 sheets of painted sheet metal ha ha.... good thing I have no interest in RV-ing
