Step by step to at least get one going.
Find an empty bank. In this example I'll use bank 0.
Press Manual.
Radio should be at channel "000"
Press "PGM"
Enter "853.825" then "Enter" (this is for enterning the site controll channel frequencies)
The top right corner should show "+MO" as being in motorola mode. If not press mode until it does
Press "MAN"
Press FUNC followed by TRUNK.
Display will show: Bank 0 ("Not Trunked!" if the bank is empty)
Press MODE until the display shows "Motorola" on the third line
Display should show "Bank 0-0 ON"
Type "4084" (This is for entering the Talkgroup number)
Use the "^" key to move to the next talkgroup memory slot then type in the talkgroup numbers you wish to add. I would venture that 4085 and 4086 may be assigned to Estes since Loveland Buses start at 4087.
When done adding talkgroups press "Man"
Press scan. This should get you started and you can add more talkgroups as you go along.
One thing you may see mentioned around RR is open and closed modes. Open mode will show a "+" under the active bank as the radio will allow all talkgroups on that site to be heard. Closed mode will show a "-" and will only monitor talkgroups and sub-banks programmed into those sub-banks. To switch between open and closed modes press FUNC followed by 5 to switch modes.
I know alot of info here but once you get the hang of keyboard programming with this radio it's not all that difficult compared to the latest and greatest models out there.
Also you can download the PRO-96 manual via radio shack
RadioShack PRO-96 Digital Trunking Scanner (200-0526)
