Which scanner works best for New Jersey State Police
buckbull
my scanner is a Whistler ws1080 I sometimes Miss Transmissions when scanning State Police Troop B was wondering if there is another scanner that won't miss Transmissions as much im looking at uniden BCD536HP or the whistler ws1095. Thanks for the info
Skypilot007
Medford, NJ
You may just be experiencing gaps in the systems coverage. It happens and there are lots of bad areas for reception especially if you're mobile with a portable in the car. Have you tried an 800MHz band specific antenna? I use a 15 year old scanner on this system and it works great.
ansky
NJ
Any analog trunking scanner will work fine. You don't need an expensive 536.
KI4SXZ
Alexandria, VA
When I drive through I don't seem to have any problems with my 536. But then again, I only really monitor the TP & GSP troops. But the site switching of the 536 is better than my 996. I have a mobile tri band on the car that picks up well, but is a little shoty down on the southern (1 - 3) part of the TP.
buckbull
how do you use a 15 year old scanner The NJSP system is rebranded i how does it work ?
Joseph11
My PRO-651, PRO-652, PRO-18, PRO-668, and TRX-2 all work great with it. Since it's simulcast, you're bound to have issues with it unless you experiment with antennas.
