Which scanners pick up Motorola Type II Smartzone?
My area is switching to an 800mhz system that uses the Motorola Type II Smartzone with Analog and APCO-25 Common Air Interface as the system voice (all from the RR database). Do I need to buy a digital scanner simply to monitor these frequencies (I'm not necessarily interested in seeing everyone's ID's or talkgroups, just listening to the actual chatter)? Thanks!
redhelmet13
4 nm se KNFW
Well, if your agency is using digital, then one of the later Uniden or RadioShack Digital capable scanners would be what you will need. The latest model out is the Uniden 396T - It has all the bells and whistles. The Pro-96 handheld and the Pro-2096 mobile from RadioShack is also a good choice depending on your preferences, (These 2 are easy to program with Don Starr's Win96 software). I have both of these scanners and they perform well for me.
Ed C.
What's the significance of the "Analog and APCO 25" as the system voice? Is there no way to use a non-digital trunking scanner to monitor this type of system? Thanks.
rescue161
KE4FHH
Hubert, NC
You'll be able to monitor the system fine with a non-digital scanner, but you won't be able to hear the digital transmissions.
APCO 25 = Digital
