which software programs will work with windows 10?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
This is entirely too broad a question, crippled. For which scanner(s) are you programming? What programs on your Win7 computer do you have?
So far it's not the programs that have issues, sometimes it's the USB drivers that give folks headaches...Mike
crippledchicken
Butler County MO
I'm using the Whistler ws1065 I downloaded the ARC500 trial version which says it's compatible so I guess I'll give it a try. Thanks!
ladn
If it doesn't run under "regular" Windows 10, you can try running it in Windows comparability mode.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The thing that will almost certainly give you headaches is the USB driver for your cable. There are significant changes in Win10 and how it determines if the driver is compatible. Beware of this....Mike
bharvey2
What about running an older version of Windows in a Virtual Machine and installing an serial card if needed?
