Which Unication G5 version to buy for the DC / northern VA area?
ecarvalho
I'm contemplating acquiring a G5 but would like a suggestion from you guys first.
What dual-band version is best for me?
I would be monitoring VSP, Loudoun County PD and Fire, Fairfax PD/Fire and DC Fire initially.
I know P25 PII is not yet available on this pager.
Thanks,
E
ecarvalho
troymail
Silent Key
In answer to my own question (possibly) sounds like I need the VHF + 700-800Mhz version and I will not be able to hear Fairfax PD/Fire nor DC Fire as both are showing P25 PII in the database.
I should be OK for Loudoun County PD/FD and VSP however (?)
https://www.radioreference.com/apps/db/?sid=3783
https://www.radioreference.com/apps/db/?sid=6524
https://www.radioreference.com/apps/db/?sid=6957
https://www.radioreference.com/apps/db/?sid=7508
E
Yup- given STARS is VHF...
ecarvalho
Correct Troy! So I've ordered one (VHF version) including charging and programming cable + software. US $660.25 ... now waiting for tracking info etc...
ecarvalho
* correction
LCPD and Fire are also PII
Sounds like I will only enjoy VSP until the PII fs is released.
ResQguy
Meh
E
Neither Fairfax or DC use Phase 2 for fire. You have to look at the talkgroup mode not just the system type.
ecarvalho
This maybe a question for another thread but anyone knows if programming the g5 from RR information is easy as in maybe exporting a system to Excel and importing into the PPS? I still have to read the programming material so forgive me if this was a silly question.
troymail
Silent Key
Apparently not - but we're asking for PPS improvements
http://forums.radioreference.com/un...see-unication-g4-g5-pagers-3.html#post2743356
I'd think the most requests for an item, the more likely we'll see those changes.
ecarvalho
Love this unit[emoji7]
Received today, programmed it for the first time and it wasn't too hard.
Here is a short clip of it receiving VHF P25 Virginia State Police (VSP) in clear and loud audio. Note that during this recording my TRX2 was in the background attempting to receive the same talkgroups and failed for the most part.
https://youtu.be/yK5z3EkkI08
Can't wait for phase 2! Would love to program Loudoun County here.
cpetraglia
Fairfax, VA
E
Fairfax shows up as PII, but is 100% Phase 1. I listen all the time. Also Loudoun is much of the time Phase 1. It's random. Also Pr. William is listed as PII, but that's only schools and busses.
troymail
Silent Key
There are alot of systems listed on RRDB as Phase 2 but operate mostly or all Phase 1.
The thing is, is the system is Phase 2 (compliant), it could go Phase 2 at any time - 1 talkgroup temporarily or all full time.
radio3353
Yes, this is a source of confusion in the RR Database. It would be nice if the admins would just put in a note if the Ph. 2 capable system is operating at the present time as Ph. 1. Just a little courtesy that would help users avoid confusion. This confusion exists with the listing for Philadelphia's TRS. It is listed as Ph. 2, but it is currently all Ph. 1.
troymail
Silent Key
Another point of confusion is the "D" vs. "T" for talkgroups.
Per the headings --
D means digital of some type (vs. analog).
T means "TDMA capable" which says it could be TDMA (Phase 2) at times but possibly FDMA (Phase 1) at other times.
Unfortunately, the combination of listing systems Phase 2 coupled with the talkgroup information and the fact that most users don't always know/provide which type any given talkgroup might be configured by the system owners, it's a bit of a crap shoot.
Also, if I'm not mistaken, some systems are set up such that certain talkgroups are always going to be Phase 2 while others will always be Phase 1 with the majority being dynamic based on the users on the talkgroup at the time (unless it's a fully Phase 2 closed system with all Phase 2 radios).
Talkgroups on one of the systems I listen to will sometimes be heard on the G4/G5 and then suddenly disappear. The primary reason is that at some point a Phase 1 radio was on the talkgroup and then left (changed talkgroups or left the site). If your radio isn't capable of both Phase 1 and Phase 2, this is one of those cases where you might incorrectly think something is wrong with your radio.
EDIT: sorry - we've kinda taken this thread a bit off-topic....
ecarvalho
Troy I also wish TGs were better defined - DC Fire has in RR a nice note stating they operate Phase I even when the system says Phase II. Nothing like that in other systems. Just DC for some reason.
I've programmed Loudoun County P25 Phase II with a couple Loudoun County Sheriff's Office and Fire talkgroups. Note they ALL show "T" in RR.
I do hear an occasional transmission on both so I assume they have mixed radios, some operating Phase 1. I will leave them programmed so when a firmware with Phase II comes out I will just add some other talkgroups.
KM4OBL
Authorized Personnel
Palookaville, USA
This has been educational for me. I've been looking at a G5 for months. I live in Alexandria - and work with police officers in all of the forces operating in DC. Will probably purchase a G5 one of these days - most likely VHF-UHF.
Cheers to all,
Jeff
ecarvalho
Glad it was helpful
Mine is VHF + 700/800Mhz
I programmed VSP (VHF), FAIRFAX PD, LCSO (they are phase 2 but most dispatch is phase 1), Arlington PD etc...
MPD is not good for me, they are encrypted
