Which XTL5000 Speaker Connector O5 Head
JimD56
KO9JAD/Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
Setting up my XTL5000 for Remote Head Operation.
Which speaker connector should I use?
A) From the XTL5000 Brick
B) From the O5 Remote Head
Jim
KO9JAD
nokones
Sun City West, AZ
There is a speaker circuit pair of wires coming off the control head power cable. The wire pair should be kinda silverish/gray in color with a White single pair molex type connector.
JimD56
There is a speaker circuit pair of wires coming off the control head power cable. The wire pair should be kinda silverish in color with a White single pair molex type connector.
Yes Sir, I know about the speaker cables. Just that the BRICK and Remote both had one. Wanted to know which was best.
K2NEC
5F6
ALSO, which Data Plug off the Brick. BOTH are "BLUE"
I tend to go with the far left one. If you choose to add another head in the future you will use the remaining one
Project25_MASTR
TX-COMU
Texas
For speaker...whichever is most convenient. Just keep in mind if you ever run a high power brick, the intended option is to run that all off the control head.
Trying to remember what I did on my Cherokee. Think I have just battery voltage and ground on the head cable and pull ignition and speaker off the brick. Of course, what I said before applies and it's not an issue as I tried to fit a high power brick under the back seat and couldn't get the seat to sit so I ended up with a mid power brick. Easier run for the overhead console mounted speaker anyway.
