Whistler 1065 with arc500 program
mr1scan
mass
Hi I have the 1065 and I am using arc500 to program it but it will only let me program 4 banks.
I tried to do more and it looked like it was doing it, but when I read it the other banks were not in the radio.
What am I missing??
Thank you
There are size limits to the info you can load, if you are trying to load entire systems in bank 1-4 you may have room out of room for additional. That's just my first guess as I do not use ARC 500.
tvengr
Well Known Member
Baltimore County, MD
On your scanner, press PROG. Press GLOB (F3). Press Down Arrow or Up Arrow to scroll to Memory Info: Press SEL. It will tell you how much Free Space is left.
Butelsoftware
Dayton Hamvention
If you want to add new data to the scanner first read from the WS1065 in the ARC500 software, then add the data in the ARC500 software and upload back into the scanner. You can not do partial uploads, this is a limitation of the scanner.
Also do you mean scanlists? The WS1065 does not use banks.
Gommert
www.butelsoftware.com
mr1scan
mass
Gommert
Yes on the scan list. I was down loading it and then adding then uploading the new info. Thanks for the response
mr1scan
mass
Thank you I will check it out. Thank you for your response
mr1scan
mass
OK Thank you I was trying to add other list/folders. Thank you for your response
mr1scan
mass
Thanks again to all but I just found the problem. You have to change the scan list in the arc500 program as well as the radio setting.
