trying to monitor from Lee Ma, Berkshire CountyWhat county are you in and which agencies do you want to monitor? I need that information for troubleshooting. If you attach your configuration file, I will check it for problems.
I don't see any talkgroups for Berkshire County on the CoMIRS system. Berkshire County uses all conventional frequencies. You have no conventional frequencies programmed in your scanner. You need to add the conventional frequencies for Berkshire County. Berkshire County, Massachusetts (MA) Scanner Frequencies and Radio Frequency Reference (radioreference.com)trying to monitor from Lee Ma, Berkshire County
thanks!
If you are not receiving State Police Troop B, You are probably suffering from simulcast distortion.The only thing on the COMIRS system in Berkshire County is Mass State Police Troop B. TG 2099 is MSP-B-PTL-1 (B2-Shelburne Falls, B3-Springfield, B6-Northampton). TG 2101 is MSP-B-PTL-2 (B1-Lee, B4-Cheshire, B5-Russell, B8-Westfield).
Troop B out of lee Ma uses the CoMIRS system. But no matter what I try, if loading from the software, or doing it manually with the scanner. I can’t seem to hear anything on the system.I don't see any talkgroups for Berkshire County on the CoMIRS system. Berkshire County uses all conventional frequencies. You have no conventional frequencies programmed in your scanner. You need to add the conventional frequencies for Berkshire County. Berkshire County, Massachusetts (MA) Scanner Frequencies and Radio Frequency Reference (radioreference.com)
Here is the response I received from my thread on the Massachusetts forum. (6) Berkshire County CoMIRS | RadioReference.com ForumsTroop B out of lee Ma uses the CoMIRS system. But no matter what I try, if loading from the software, or doing it manually with the scanner. I can’t seem to hear anything on the system.
