Whistler Skipping Words On Long Conversations
P_Eye2000
Port Orange, Florida
Can anyone tell me why My Trunked WS1040 setup will do like a skip a word on long conversation, Kind of like a refresh..? Example Medic giving vitals to the ED department while on call or enroute to hospital.. Ant help on what settings I may try would be of great help.. Thanks, John
CT
Are you using Priority?
Priority Mode
" Conventional Priority Scanning will give priority to conventional objects that have their priority mode set to 'On'. The scanner will sample the conventional objects for activity periodically while scanning and monitoring other objects. This sampling will cause a brief muting of received audio when it occurs while another object is active. "
P_Eye2000
I can see along the bottom in any mode (P or p) Wx PRI Check Pops on the LCD under the above display.. Is there a way to stop ALL PRI Checks..? I use the scanner only for Trunked in my area...
