I did....
Mpt1327 is hardly used in the US and thank god it’s dying a slow painful death in the uk too. Most inefficient trunking system known to man.
Might want to double check about TETRA not being used in the USA. It’s favourable upgrade point coming from MPT1327 and even DMR Tier 3lolbannalol2 - TETRA wont be in American Scanner Radios, we don' use TETRA. but, Whistler dose sell International models of their Scanners, possibly those will include TETRA.
But, do these new models track DMR/NXDN conversations like Uniden?
For the folks that own a TRX-1/2, could an upgrade be possibly done with the scanner, as in you send it away and pay a fee to upgrade it to mirror the TRX 100/200 or is that not feasible?
Why would Whistler even consider doing that? it makes no sense to offer new scanners if existing scanners could just be upgraded. That makes zero business sense at all.
If you want the features of a 100/200 then you need to purchase one of those 2 new models.
Marshall KE4ZNR
It's likely not feasible anyway, as the new model will have a different receiver and probably a different display as well. There's not much point in an "upgrade" that replaces everything except the outer case shell. A new unit would probably be cheaper anyway, when you factor in the cost of gutting the case and installing new everything by hand, vs running new units off an automated assembly line.
I'm saying it's unlikely, not that it wouldn't be great if they did.And because we're hoping there's a new design because, aside from the built in remote head capabilities which are amazing, the current design leaves plenty to be desired. Just my opinion.
There's been no suggestion that I've seen that anything SDR like is being added other than that presumably they'll add a CQPSK demodulator for LSM to the DSP functions (and possibly/probably change the existing AM and FM demodulators to DSP versions as well).A SDR receiver design is significantly different than a standard receiver. SDR also offers the possibility of waterfall and/or band scope displays, which wouldn't work with the current display screen. Also, if there was only a bare minimum of design changes, why buy the new model?
But you DO NOT have to digitize any more than the signal you want to receive, as is available at the output of the existing narrow IF filters.You have to have SDR to do I/Q demodulation. I/Q denotes a particular type of digitized RF data.
Sent from my SM-N9005 using Tapatalk
