Hey guys,
I've been working to track down a reception issue on my TRX that I'm actually using as a base public safety scanner at my house. There is something, either in my house or nearby that's causing a very noticeable decrease in reception. I am running the scanner to a roof top tuned antenna with great line of sight in all directions. Yet I get the same, if not better reception with the rubber duck on the scanner away from my house, even in low lying areas. And my house sits on a hill.
I've already cut off power to my entire house to see if the interference was coming from the house, no change. I've tried several different roof top antennas, and even tried taking the handheld on the roof and plugging it directly into the antenna, eliminating the feed line. No change.
I've been reading recently that GRE scanners can be very prone to overloading and "desensing" from strong signals. The only transmitter I have near my house is an AM transmitter tower very close to my house. But the AM transmission power is cut from 5000 watts during the day to 137 watts at night, and I don't notice a change in reception at night. The closest FM transmitter is like 10 miles away.
I've also done a full spectrum sweep on the scanner itself and found one problem frequency that sounded like pager data broadcast that was very strong. I've already got a notch filter to cut out that interference.
Can anyone shed any light on the attenuation settings in the Whistler scanners and what the settings actually do? I can't imagine they will be much help, but I'm at a loss for what else to try. I'm scanning almost all VHF high public safety range, and a little bit in the mid-400's Thanks guys!
