Whistler trx1e hanging
zebb
Greetings
Have another issue with whistler trx 1e programming.
Scanner comes with preloaded channels air, plus digital pmr 446 nxdn. Ect.
When adding new lists to this folder, you can add a few check and all ok, then all of a sudden the first object in the list, ie air freq.. Will not upload into scanner using the scan lists on scanner, just sits there hanging.
However uncheck it, all the others still work ok.
So created a new v folder and uploaded new lists, 32 of them all good data all updated software from start of use, as checked ok. Tried different 8gb scandisk sd cards ect.
Still same issue in new folder first object fails to load into scanner using scan scan list.. Have to remove Battery's to get it back to start again... But any combination or single object seleted works good..
Anyone else had similar issue.
Thank you..
