savage308
i have a gree -psr 500, i plug mine into my ridgid work mate radio using the mp3 plug in, i use the scanner on minimum volume and crank the radio like a amplifier, been doing in now for 5 years outside daily
Yeah, scanner manufacturers should stop using efficient push/pull amplifiers just so streamers can avoid the huuuge hassle of installing DC blockers...Yup, seems like we can no longer connect scanners to anything else that is itself powered, or else the other devices DC current can flow back into the scanner and damage the audio circuit.
But look at the upside...the parts removed to cause this makes our scanners 10 cents cheaper to buy...yay!
Paul
So, for testing, I bought a refurb WS1098, and attempted to attach it in place of my old PRO197, same power, antenna, and 3.5mm stereo line connection to the PC. NO AUDIO...get a slight little blip or pop when channels start to RX, but thats it. Tried headphone, which does work, but extremely low audio, not loud enough for the levels of my needs. Headphones attached to the speaker jack work very nicely. Since Whistlers position is that it is not possible to attach the speaker output to a PC, can someone with a Whistler scanner who has it attached to a PC specify what I am doing wrong?
Paul
