Whistler ws 1040 Volume/squelch Problem
rbluesky
Anyone having a problem with your volume/ squelch control ?? such as static volume drop out
if your are Please contact Whistler and let them know if there is enough people calling they just might get this problem fixed. thanks
DeeEx
New England
Be specific. When monitoring what mode, at what signal strength, memory channel versus search mode, etc.
My 1040 has always been well-behaved.
Check your internal antenna jack where the conductor is soldered— a lot of handheld scanners whose antennas get bumped will begin to have on again/off again RX as the result.
Are your speaker wires intact?
Ronaldski
MI DB Admin
Bay City MI
That happens with all those radios that use that volume/squelch, depending how old and how much its adjusted no doubt. I know at least back to the old radio shack pro 106/197's and read with other earlier models. I recall reading that its a special knob setup that was made just for scanners.
Been brought up in the forums a few times years ago, even if you got a new part it will be static as well eventually. Found this if it helps and dont know how long it had helped ... Static in Volume
A forums search Search results for query: volume knob static
