Hello all.
Have a question regarding the WS1040. A friend has recently purchased his scanner due to his friend owning one. Both sit in the exact same spot with the scanners and one has an issue with receive and signal loss. The other, his scanner works A 1. What could be causing this issue and, can it be something that can be fixed in the programming? I suggested he may want to call Whistler right away and advise, perhaps returning for a replacement scanner. He has the receive / signal loss problem often and is frustrated even after trying different antennas as a solution. If any one has heard if this is a known issue with some of these WS 1040s or not, would be helpful.
Thanks.
Thanks.
