Whistler WS-1098 and WS-1088 Recording Issues
Radiorandy
Toronto,Canada
I have both of the above units. I recently had a use for the recording feature on both units.
I have set up conventional channels in the same scanlist. There are P25 and analog channels. I am finding on both radios that the scanner records the P25 channels but it does not record the analog channels.
Has anyone had this same issue with their scanners? Is there a solution to this problem?
Randy VE3OGB
Radiorandy
Toronto,Canada
All the channels that are in the scan list are marked to record. The issue is that only the P25 channels are being recorded!
Randy
tvengr
Well Known Member
Baltimore County, MD
Is everything conventional or do you have trunked systems? Under the Advanced Features tab of EZ Scan, you have a recording Global Enable setting.
Radiorandy
Toronto,Canada
As I listed in my original post, all the channels are conventional. The Global setting is enabled!
I'm trying monitor and record activity on my repeaters that are capable of both P25 and analog use.
