Short answer: Yes.
The Minnesota ARMER system is pretty complicated to program. It consists of several sites all working together to provide a good communications network.
Unfortunately I'm not familiar with the Whistler line of scanners, however I'm sure if you looked at Youtube, you might find some videos to help you.
Generally speaking refer to this page for the data applicable to the ARMER system:
Allied Radio Matrix for Emergency Response (ARMER) Trunking System, Various, Minnesota - Scanner Frequencies
For the site, you'll want to program the Anoke Co Simulcast. For talkgroups you want to scroll down to the Anoka County Talkgroups and program those of interest to you. I also recommend programming all the Zone 1 Interoperability talkgroups, particularly METCOM (lots of good stuff there) as well as the Statewide Interoperability talkgroups.
That would be the basic stuff for your area. As time goes along, you might want to spread your wings and try Hennepin County stuff and perhaps even Minneapolis, though you might be a little far out from Minneapolis. Should you do so, since principles apply choose the county site(s) and county talkgroups.
From experience: programming a new scanner on a complex system (and ARMER is as complex as they get), is challenging for anyone, especially a newbie. So be prepared for things not going prefectly at first - give yourself permission to make mistakes. Be patient and you'll get there.
(FWIW, I have some good friends up that-away and always get confused by 107th Lane and 107th Avenue. I suspect you are on the FD there and got that area figured out. So you should be able to work through the scanner OK
