Whistler WS1065 Display shows "Nothing Enabled"
hrill
Wilmington, MA
My scanner was working just fine, and has been for the past year. For reason's unknown to me, today it just stopped working and I can't get it working again. Every time I try to upload a file, when it finishes and reboots, I see the message "Nothing Enabled"
Does anyone have any insight as to what could be wrong?
Thanks in advance
Swipesy
Northern Ohio
Thanks in advance
Nothing Enabled means that you do not have any ScanLists (1-20) enabled or you do not have any TalkGroups/Frequencies assigned to an enable ScanList. Check your programming to make sure you have TalkGroups or frequencies assigned to the ScanList you have Enabled
Nasby
Ohio
Thanks in advance
I’ve had this happen before on mine. Not sure why (possibly some sort of power surge).
The fix was reprogramming the unit as all of the frequencies were erased.
tvengr
Well Known Member
Baltimore County, MD
Make sure you are plugged into the PC/IF jack and not the headphone jack. If your cable has a mono adapter, remove it. The WS1065 requires a stereo plug. Are the scan lists enabled? If reprogramming does not fix the problem, please attach your programming file so we can take a look at it. You will need to zip the file to be able to attach it. Click on Attach files and open the zipped file.
