I was imprecise in my terminology DonS. When I wrote "speaker out" I thought people would understand that I meant "speaker output". Which is what the list below refers to as "External speaker output on rear panel of main unit". Which in the radio parlance I'm used to is a "speaker out". Not a speaker physically pointing out of the rear panel.
IOWAGUY1603, we don't have to wait to find out who was right. ME!
I would.
- USB jack on front panel (main unit, not "removable" part).
- Headphone jack on front panel (main unit, not "removable" part).
[*]External speaker output on rear panel of main unit- Internal speaker points out of top of main unit
- SD card ("standard" size, not micro or mini) on main unit behind removable panel.
- Main unit and removable panel either a) attached to each other (magnetic, with a latch), with a direct (no cable) connection, or b) separate from each other, connected via 8-pin RJ-45 (i.e. a plain old Cat-5 cable... I'm using a 25' Cat-5 cable I had lying around)
- Removable panel has power button, volume/squelch control, and PSR-800 LCD, LED, and buttons. Volume/squelch knob is a rotary encoder that can also perform up/down/select functions (i.e. in menus).
