If you leave out that freq, then you will miss radio traffic on the system. That is, in fact, the object of trunking - with each conversation on a talkgroup constantly hopping between frequencies on the system to spread the load and make efficient use of the frequencies (basically the whole idea is that not everyone will want to talk at once, so you put a lot of channels in the system in the form of talkgroups and not enough frequencies to support them all at once - so if someone from each talkgroup all keyed their mics at the same time most would get a busy signal). The control channel tells their radios (and your scanner) which frequency to jump to for each transmission on a given talkgroup milliseconds after the PTT is depressed, so to everybody it sounds like you've been on one channel the whole time (when in fact you've been hopping between 7 voice frequencies - the 8th allotted to the control channel, which rotates in its logical channel # assignment).
Linuxwrangler said:
But your experience is approximately correct. With 8 channels, 1 is control, 7 for talk. One of them is bad. So the expectation is 1/7=14.3% while you are seeing 40/252=15.9%. Pretty close.
Like we've already talked about, if you lock out 860.7125, you're going to miss approximately 15% of everything said on the system. It's an unfortunate fact. Your options are, listen to the beeps 1/7th of the time since they seem to be the result of a technical error somewhere during the system's rapid expansion - OR - lock out 860.7125 and miss 1/7th of the radio traffic (and possibly something fun and or important).
Linuxwrangler said:
They are working on the system. You will still hear lots of radio-tech test-counts. Talked to one of the EC officers this morning and he said that they are still having intermittent static/garble/beep problems. Seems to mostly be related to 860.7125. When that is in the mix, things sound bad. When it is not, system sounds fine.
So be patient, it's probably not your scanner.
Again, it's been previously talked about in the previous two pages of this thread.
Any new developments though guys?
-Inigo
