chris8video
I have a 436 and use Butel ARC536 basic. I have about 30 counties worth of programing in it. Can I use it to program the 200?
I'm not sure about using the ARC536 program but if you have the 436 programmed like you want you can download from the 436 into Sentinel and then you "should" be able to turn that around into the 200. I would assume this is the only practical way to do this since I think the 100/200 can only be programmed by Sentinel at this point.
Also, Sentinel will have the full database in it to pick from so unless you have some super customized data you may not need your existing programmning. Or at the very least you can load your custom work in conjunction with what comes in Sentinal.
I have cross checked my custom TGs with the Database and I haven't found many discrepancies, just a few naming protocols that I changed to my preference.
