Boatanchor
- Joined
- Jul 17, 2011
- Messages
- 991
I've wondered for a while why certain scanners are so susceptible to interference from FM broadcast on the VHF bands when connected to an external (mobile or base), broadband antenna.
Many of us enjoy monitoring the VHF aircraft bands or the LMR/Ham bands between 108-220Mhz.
In many cases, the signals we are trying to receive are distant and weak.
In my case, if I connect a PSR-600 and a BCD-996XT to the same base antenna via a splitter, I am often able to monitor weak VHF air/LMR comms signals on the Uniden while the PSR-600 hears nothing at all. Hitting search on the PSR-600 is an exercise in futility as the scanner stops every few Khz or so on what sounds like FM broadcast interference. However, If I then connect an FM trap inline, immediately the PSR-600 springs to life and begins to act somewhat 'normally'...
The trouble with FM traps, is that all of them, no matter how much money you spend, also attenuate the bottom end of the aircraft band.
I've suspected for a while that this phenomenon was due to inadequate band/high pass filtering within the GRE RF design. The following attempts to show why this occurs and hopefully, scanner manufacturers will take notice and improve future designs..
The following photo depicts the front end filtering characteristics of the PSR600 and PSR500 scanners when on the 108-230Mhz band. Note that there are actually five front end band/high pass filters in the GRE scanners covering the 27-54Mhz, 108-230Mhz, 220-400, 400-512 & 750-1300Mhz ranges.
The problem with the GRE scanners on VHF, is that the 108-230Mhz 'filter' offers no protection at all from FM broadcast signals in the 88-108Mhz band.
The spectrum analyzer plot below, depicts the front end filtering characteristics of the PSR600.
Marker '1R' is centered on 150Mhz, as a reference point. The point we are interested in, is marker '1'. Marker '1' is located at a frequency that is 6dB down in level from the main filter passband. In the PSR5/600, the 6dB point is at 75Mhz! Why the rolloff of this filter was selected so low in frequency is beyond me. Anyway, even 6dB is not very much attenuation when it comes to reducing very strong signals.
In other words, when the PSR5/600 is tuned to a frequency within the 108-230Mhz range, the scanners front end bandpass filtering is allowing everything from 75Mhz and up, to pass through to the pre-amp transistor unimpeded. This is a major problem, because very strong FM signals being applied to this pre-amp transistor can then produce blocking and or Inter-modulation products that will interfere with what we want to listen to. Unbelievably, there is absolutely no attenuation of 88-108Mhz frequencies in the GRE PSR5/600 scanners!
So, now we know..
Hopefully, in future designs, manufacturers will spend a little more time getting the bit behind the antenna socket right, before they move on to the bells and whistles sections.
There really is no excuse for such an oversight. Was it simply laziness on the part of the designers, or was it due to cost cutting? Either way, improving these front end filters could have been achieved with a simple band-reject filter and less than $1 worth of SMD parts..
So, now we know..
