walter900
- Joined
- Aug 24, 2005
- Messages
- 220
- Reaction score
- 4
Why does Win 500 "Endtone Threshold" defaults to 80 after a reset?
Hi,
If you open up a Win 500 file, load up a file, and then click on the "Extended Settings" tab you will see a box labeled Motorola Trunking. It will have three settings in it "Subaudible start delay", "Endtone pattern", and "Endtone threshhold".
*The setting that is named "Endtone Threshhold" should read a value of "250" by default.
Now, lets leave what i just said for a moment and now move over to a retangular box titled "Important", (over to the lower right side of the page).
It reads as follows;
IMPORTANT
Some settings on this page can have detrimental effects on
the radio's performance if set "badly".
Click this button to reset all settings on this page to default
values.
OK, so i clicked the button (which is the actual box the words are written in), and under the Motorola setting of "Endtone Threshhold", the number changed from 250 to 80 which i do not feel is the right number. Is there a purpose why the Win 500 program changes the default of 250, so that it defaults as 80??
Hi,
IMPORTANT
values.
