why hasnt a vselp capable scanner been made ever? :?:
Cobra_Commander said:What can i use to hear vselp with the pro-96
Cobra_Commander said:and when do you think this vselp system will go to a P-25 capable system i can monitor? :?:
Cobra_Commander said:How would i program a ASTRO Saber to hear the cleveland vselp system? what do i need to program it with their frequencies and talkgroups from the rr database? :?:
Is the "end of 2008" the beginning or end of the process? If it's the end, then when do you think the first P-25 will go in? Surely there would be a transition process...?FPO703 said:On top of that, by the end of 2008, Cleveland will have a new P-25 system in place.
eorange said:when do you think the first P-25 will go in?
mancow said:Cobra_Commander said:How would i program a ASTRO Saber to hear the cleveland vselp system? what do i need to program it with their frequencies and talkgroups from the rr database? :?:
It's a whole nother world!
You would need a radio with older VSELP firmware and DSP etc....
The programming equipment (rib, cables, software, etc....)
A system key file
They program using the 3 digit hex equivalents for the talk groups
Plus, you can only scan 10 or maybe 16 talk groups max. I don't recall right now which it is.
Bottom line is that it's really not worth it. Just wait it out and get a new scanner that can follow the new system they are planning on putting in place.
mancow
Cobra_Commander said:already have the newest digital scanner the pro-96 which i think will be good unless they go to a digital edacs system then i will not be able to monitor them at all. :evil: :evil:
mancow said:What about the re-banding? Maybe I missed the info regarding the 96 and how it will be effected.
mancow
mikey60 said:mancow said:What about the re-banding? Maybe I missed the info regarding the 96 and how it will be effected.
mancow
It should be able to be reprogrammed to operate on the new bandplan, assuming it holds in it's current form. It'll require putting in 6 tables to work though.
Mike
