bigcam406
i recently purchased a psr500,and the first thing i noticed was how much more sensitive it is.mind you,im comparing it to a uniden 898t and a bc95xt.all 3 have their purpose,but im really impressed with the psr500.just my .02.
Just one question? Do you have the latest firmware for your Uniden scanners?
This is totally untrue unless you are specifically referring to the GRE digital scanners. I've manually programmed all of my GREs, and the thing that makes it tough w/o a computer is all the alpha tags. But no one says you have to use them. That's better than no alpha tags on many Unidens.GREs are too complicated and involved to program without a computer.
GRE scanners to me, seem very easy to do firmware updates and program. Unidens on the other hand always seem a little more involved with firmware and programming issues. I've had my fair share of both brands and I like both for different reasons, GRE's just are easier for me to use and understand, maybe it's just me.
Either scanner is reasonably easy to program by hand to make it work but Alpha Tags are tedious on any unit. GRE does have the upper hand though with both system and alpha entering by hand.This is totally untrue unless you are specifically referring to the GRE digital scanners. I've manually programmed all of my GREs, and the thing that makes it tough w/o a computer is all the alpha tags. But no one says you have to use them. That's better than no alpha tags on many Unidens.
I spent over $500.00 for my 996T and got something that was useless for what I wanted. Over a year later and after downloading and applying 3 firmware updates, it still doesn't work well on P-25 systems. Now you want me to spend another $500-$600 for an XT to see if that will be better. NO THANKS!
Although EVERY scanner I use is/was made by GRE, I won't go out on a limb and say that it is the only brand I'll buy from here on out. I believe in rating each model on its merits or demerits. The last thing we need is for GRE to become complacent.
But having said that, GRE beats Uniden hands down for me. I don't want a scanner so small I can't see it. BIGGER (displays) are better. I want CLEAR text on the displays, that means a "boring" "blocky" font, not something "fancy". Overload and intermod is only a problem when feeding the scanner too much signal - being too close to a transmission site, using an amplifier, etc. Notch filters are a better way to go rather than using a scanner so "deaf" it can't pick up what you want to receive.
Yup, SIZE matters. And I want a damn near HUGE display that I can read and a scanner that won't "slip through my hands". GRE wins this one.
I'm in the market for a new digital scanner and like you, I like bigger displays, however by looking at the GRE and R.S. scanners, their displays look tiny when compared to the Uniden 996 models. This size difference is the main reason I'm leaning toward getting the Uniden rather than the GRE or R.S. model. There are other factors that I'm considering as well, but the ability to easily read the display is one of the most important factors to me. For the consumer who really values having a huge display, would Uniden not be the best choice?
I can't do anything with uniden scanners. I have their nascar one and it's basic functions are too complicated for me to learn without a manual. Of course I went and downloaded the manual, but I never needed the manual for my Pro-164 unless I needed help with trunking or say fips codes.
I dont think you can go wrong with either one, both scanner brands are going to do one thing better then the other brand. One brand might even work better on the system your monitoring then the other. Choose the one you think is best for you.
For me, I'm not buying anymore digital scanners until they get one that provides excellent reception on P25 9600 baud simulcast systems.
