Gre
And your scanners listed below dont include a single Uniden..
Yup. I practice what I preach.
yet you want to debate how much better the GRE is side by side with the Uniden that you "see" once in a while. .... (not just borrowing from a friend for 5 minutes)
LOL. What makes you think I have only used one for "5 minutes"? I actually have some Unidens here (yes more than one). But they do not perform, and awkward to navigate and therefore do not belong on my tagline.
Correct the Unidens arent as sensitive (the GRE rocks in low signal areas), but start using a GRE beside a pager tower or urban area and your "superior" GRE will be silent due to overload while the Uniden keeps picking up stuff. Not so superior in that case.
I have an outdoor antenna and monitor in a radius of about 100 miles. The strongest signals from my antenna (measured by RF meter) are broadcast FM stations followed closely by a couple of paging transmitters 2 blocks from here. A filter removed the FM broadcast and the paging transmitters are not a problem.
I mentioned it earlier; I have schematics for my scanners, but not the Unidens. I know that they do have "filters" in the front end to select the band desired. In order to have an overwhelming amount of signal that causes overload, desens, or whathaveyou; the signal must be in the same pass band. Not only do I live in an urban area, I travel the west coast a lot and have never had a problem with my GREs, and run from external antennas when not portable.
... you're just backing GRE (whatever they have you find superior - im sure if it had no screen youd say they were superior still and the no display means clean lines or something), and I guess I should id expect that in a GRE forum.
LOL. Not from me. I've seen junk from every company. Don't get me started on the firmware bugs in GRE scanners that I noticed in the PRO-92 which still exist in the PSR-300.
I dont mind the debate, each unit has + and - im just tired of people comparing the units (saying how far superior theirs is) if they dont use both daily.
I don't have to use something "daily" to know if it is good or not. I want to listen, not compare scanners all day. When something is connected in the exact same environment and does not live up, it is disconnected and set aside (to collect dust).
