Propgtn Why So Many 20m Stations at Night?
sunwave
Oklahoma
Last night I had a buffet of signals at midnight on 20m. I use a RSP1a and MLA 30+. I was hearing Europe, England, and Madeira Island. 20m normally closes in the late evening around sunset. This phenomenon of a crowded 20m spectrum at night brings the question WHY?
Image of the waterfall at midnight local time utc -5.
I have enclosed the recording of Madeira Island on 14237.8khz usb. It is archived in zip format compression, RR Forums won't take mp3 files is why it is zipped.
  • SDRuno_20230709_005417_14237800HZ.zip
Token
It sounds like you are used to propagation during Solar Cycle minima, but when propagation supports it, like during solar cycle maxima, the 20 meter band rolls 24 / 7. Looking back at my log books during the peaks of Solar Cycle 20 (1968) and 21 (1979) I see that many of my best contacts were during local darkness.
I have seen conditions where 20 meters did not shut down for weeks on end. All day and night it was open to someplace.
T!
jwt873
Woodlands, Manitoba
Years ago I had a job where I had to do shift work. After the evening shift, I normally got home at 1:00 AM. I used to work the Pacific on 20 meters.. (Australia, New Zealand, Japan). 15 meters was pretty good at times in the wee hours as well..
13dka
Germany (coast)
One contributing factor was likely the (IARU HF World Championship?) contest on this weekend. This usually boosts both activity and TX power and makes operators pull all-nighters. :)
But why I'm really here is that I want to emphasize on (antenna) takeoff angle:
That's what I was thinking too for the first 40 years of SWLing. :) Imagine my surprise when I found out the opposite, just of all in the past sunspot minimum!
The mechanism is pretty simple - the MUF also depends on "angle of incidence" - signals at NVIS angles have a lower MUF than signals bouncing off the ionosphere at a flat angle. Now when the MUF is decreasing during night (or isn't terribly high in first place, due to a lack of solar activity during a solar cycle minimum) two things happen: 1) most of your "radio neighbors" go to bed and 2) the ability of the ionosphere to reflect shorter distance signals from steep angles decreases (that's one reason why 80m is such a "night band" - the MUF rarely sinks that low). What's left are signals coming in at very flat elevation angles from the far points beyond the horizon. They are usually not that loud but they are there!
Now there are a few more factors playing a role in this, like your location (latitude!) on the planet but your antenna is the most important one: Basically, most contraptions us mere SWLs string up and put out for an antenna are not exactly great (sensitive) at low elevation angles. In fact, in most cases it's pretty hard to achieve ideal radiation (or in case of reception, sensitivity-) patterns for DX and in case of horizontal wire antennas, an antenna height of 1/2 lambda is needed to achieve at least some low angle sensitivity. Another example are small magnetic loops (SMLs): They give you generally consistent vertical patterns much more independent from antenna height and ground conductivity but this is also their general disadvantage -- they never give you that much signal from low elevation angles even if you put them up high. The result is what I experienced most of my life - after sunset, the MUF goes down, signals coming in from steeper angles die off and what's left is a band looking empty....unless there's a really "big gun" transmitting on the other side.
Fast forward to 2017-18: I became a "DX nomad" and started experimenting with antennas at the coast. This is important because this location gives me low noise and a very conductive ground. What I didn't know back then was that putting up any horizontal wire antenna there is even worse - the better the ground, the steeper their vertical pattern becomes when they are not at their optimum height over ground. An SML was much better than that but the hobby still was a bit boring after sunset unless the conditions were somewhat "elevated". When I was too lazy to put up much of an antenna using the 30ft fiberglass pole I bought for getting some elevation for either dipoles or the SML one day, I just ran a vertical wire up that pole and that changed things dramatically!
It took me quite a while to understand that: The very conductive ground near the ocean freed me of the need for radials or a ground network to make this simple vertical monopole antenna work just the right way to make the nights surprisingly exiting, it has a quite flat, donut-shaped radiation pattern without these extra complications. Again, this was at the bottom end of cycle 24 and all of a sudden the nights were actually much more exiting than the days, quite often I heard all continents in one night and - unless the sun had a little hickup - the generally quiet space weather made these basic "solar minimum" conditions very consistent! I started spending a lot of nights out there and even in case of a little geomagnetic disturbance, only 17m really "closed" a few times, 20m just suffered some degradation most times but almost never really shut down.
The reasons for that are: A flat vertical antenna radiation pattern more than anything else, and low QRM so the generally weaker, distant nighttime signals don't drown in it. The proximity to the ocean adds ~10dB of gain as a sweet icing on the cake, but that won't do much good without a flat vertical antenna pattern.
Boombox
We are nearing the Solar maximum for Cycle 25, the peak of which was projected for 2025, but more recently it's been projected (by some) for the end of this year. During Solar maxima, 20 meters will stay open to Australia, NZ, and other places into the early evening. That's the way it's been in the past, and it's that way, to a certain extent, this year.
Also, remember, 20 Meters is probably the most popular HF ham band.
Mtindor and 13dka mentioned a contest, and yes, when there is a contest, that's when the non-active hams come out of the woodwork and you'll hear a lot more activity.
db_gain
Back in the jt65 craze days, I could never get east of Poland. Time and again, no Russians or asians at all. Morning for asians, late afternoon for eastern euros, etc, nada. One late night when getting ready to shut the rig and pc down, for giggles I fired up on an absolutely silent 20m jt65 and a guy in Russia came right back to me, he was the only guy on the band. You never know when a band is open or where unless you try.
Also, an old (hiram percy) maxim is "any station in darkness can hear any other station in darkness", or something like that, and of course there's always Gooch's paradox, rf gatta go somewhere!
merlin
DN32su
20 meters is just about the sweet spot for propagation day or night.
I get a good 1000 KM during day hours and have had signals half way around the globe at night.
