Mine is experience over several cars. I take that over anyone's post. They have worked fine. If one does not keep their car clean and waxed, there will be problems with magmounts and other things. Doing it now is in the same line as the people telling me to trade in this dependable car for an untested new one. (I have always had the tools and parts to do the permanent install.) Additionally, using a magmount gives me the flexability to try different antennas and pick the best one (which I do)--something sometimes not possible the other way. I suspect doing that comparison and tests likely gives me better performance that just picking an antenna and installing it permanently--and comparisons with others on 2m using simplex over decades of commuting shows that I do at least as well. The only negative I have found is about every >5 years having to replace the rubber liner where the coax passes through (neglegible cost) and being careful when I shut that door and careful attention to the cables tension so that it does not rub the roof. Rest assured, if performance were an issue, I have have ditched the magmount long ago. Anyone with scratches like that is the result of not taking care of their car--not the magmounts fault. When I wash and wax my car, I take the magmount off and make sure the area is clean. Over those 400,000 miles, one cannot not tell where I put the magmount and I have to take time to re-center it when I put it back on. It is true that the car has outlasted 1 or two magmounts that I chose to replace. And my information is from 30 years of first hand using magmounts. Nothing wrong with a permanent mount if you just want a couple antennas and want to do that work but the attack on magmounts is exaggerated by extreme examples that could be equally countered by people showing botched effects of permanent mount installing.
You are certainly an exception to the rule, then. You've also shown that you don't fully understand how an NMO mount works - you can change antennas everyday if you want to. I change antennas on mine fairly often for the same reason - try different ones. You just unscrew one and screw on another to the NMO mount. Easy. No unsightly coax running around, etc. Everything nice and hidden and all the flexibility in the world to try different antennas...and with better performance than mag mounts (regardless of what you say) because of the difference in how the mounts function electrically/RF-wise.
They may perform "fine" for you but it is common knowledge that the manner in which mag mount antennas operate (RF-wise) makes them subpar performers in comparison to NMO antennas. If you want to use mag mounts and are fine with the performance then that's up to you, but making claims that most of us know aren't true doesn't help you prove the point you're trying to make.
YES, damage on the vehicles shown in this thread
is from the mag mount antenna - if it hadn't been on there, the damage wouldn't be there. 100% the fault of placing a mag mount on there...
I do not expect, nor is it really my goal, that we can change your mind or convince you otherwise, but much of your paragraph there actually goes to support the spirit of this thread and not the point you're trying to make; we read between the lines. We have much experience, too. I've used mag mounts! I've then changed to hole mounted NMOs and saw the improvement first hand. My experience and the experience of many others.
It's not an "attack" on mag mounts, as you say - it's sharing factual information to help others (the true spirit of a ham operator), in hopes that they will take it to heart and do things better than the easy, ugly way that won't perform as well. It's up to each person to decide, though. You seem to have made up your mind and that's fine...but, I would hope you'd be open to at least learning something new.
I strongly encourage you to at least click the following link and read the 3 or 4 short paragraphs (take you 90-120 seconds tops) that are presented in that section, that's it. It's just some simple information that you, and everyone in this thread, should know. Especially paragraphs 3 and 4. Here's the link:
http://www.k0bg.com/antmount.html#mag
Have a good one!
