I have a Tram Magnetic mount that has caused no scratches whatsoever. It has a rubber boot on the bottom. I use the Tram 3500 model.
We also sometime poop out the interior light to get a look see.
I have had no issues,
A couple of things I've learned from this thread...
1) Even when presented with evidence, some will continue to dispute and deny it.
2) Even though they are free to still continue to use mag mounts if they so choose, some people feel they have to try to defend their actions (on someone else's thread...) and, by doing so, will prove #1 true.
It's your install and your vehicle - if you want to use a mag mount and are fine with its performance then go right ahead...but don't try to convince us it's just as good or doesn't cause any issues...the evidence, as presented here and elsewhere, is against you.
Plenty of videos showing how to drill hole
But i can't find a video on how to run the cable through the interior towards the front of my expedition. That's where i need help
No issues with mine either.
The bigger issue that often gets overlooked is how to get the coax cable into the car, and in your case, RF radiation to the occupants.
So.. I'm stuck with what I've got..
When I have a passenger with me I talk to the passenger and not on the radio. I mounted the antenna on the passenger cowl to keep it away from me.
Yes, that's a Laird or PCTEL 1/2 wave VHF antenna in the provided picture.Might be taking the thread a little off base, (but it does deal with holes vs no holes).
On the video above, yes I'm aware of the clamp on hood mounts similar to trunk mounts. I routed my wires to the engine bay in the same manner.. I did consider perhaps using a clamp on hood mount, but again my mag mount worked so well, I never did get around to pursuing other solutions.
Out of curiosity, I wondered what the 'pros' did. Wranglers are used by law enforcement etc where rugged terrain has to be patrolled. I came across a picture of a US Border Patrol JK. They drilled a hole right in the plastic top. I'm guessing they used a half wave. The thought of doing something like this crossed my mind, but my top is rarely on in the summer so it wouldn't be practical.
